If you have deep cycle batteries for other things like a trolling motor, you could set up an alternator kill switch and run off the batteries. Usually nets 10%. More if you can keep the voltage at 14V+
Tire pressure. Are you up to max sidewall? The heavier you are the more rolling resistance comes into play.
Vortex generators are old tech. My new and improved vortex alternators are unstoppable.
"It’s easy to explain how rockets work but explaining the aerodynamics of a wing takes a rocket scientist.
