On the trail, going to track it like a blue tick hound!!!
From what i've read in the article's, HCCI sounds promising. Check out the other link's i just came across.
Engine shows diesel efficiency without the emissions
Green Car Congress: Honda Making Significant Progress on HCCI Engine for Hybrid Application
ABG Tech analysis and driving impression: GM's HCCI Engine
GM HCCI engine can operate at idle
GM Rethinks Engine With HCCI - Video - Homogeneous Charge-Compression Ignition - General Motors - Popular Mechanics
HCCI Engines
Homogeneous charge compression ignition - Wikipedia, the free encyclopedia
Homogeneous Charge Compression Ignition
Also mentioned in the reader comments a company called Vapor Fuel Technologies -
Vapor Fuel Technologies | Home to the VFT Vapor System.
Keyword search: HCCI engines
P. S. Might be ole school,keep on wrenchin.
Here's an ole mechanic's trick o'the trade. If you got a diesel that's hard to start. (Be extremly careful) 1.) lightly satuate a mech's rag w/gas, 2.) hold over air intake (tight), to allow fumes (vapor), 3.)crank engine it should start, barring any mechanical failure's, 4.)do not repeat more than a couple of times without further investigation should engine fail to start.
