Old 07-11-2009, 11:23 AM   #17 (permalink)
hondo434
Alty-magnet - '06 Nissan Altima SE
90 day: 33.83 mpg (US)
maxi-magnet II - '12 Nissan Maxima S
a thought, It seems you trying to make a refigerator that lies flat on the ground. Because you will have to break up chest into differt sections and make fans move air to where you want it Etc. You will probably end up with a make shift refer laying on ground with not much savings. If you know how to work with refrigerent and work on compressors maybe you could just take refer which is all set up with compartments you'll need, lay it flat and reconfigure compressor so it sits upright in unit so it can function.
Another answer to the previous question about compressors cyling to quickly is because compressors can build up head pressure and can affect the compressors ability to restart, thus possibly burning out motor. Compressors should wait about 3-5 minutes before restarting to illiminate head pressure. This is true of all compressors,A/C,refer, freezers .
