Old 07-11-2009, 07:15 PM   #39 (permalink)
LUVMY02CREW
LUVMY02CREW's Avatar
TANK the fifth - '02 Chevrolet S10 Crew Cab 4x4 LS
90 day: 20.44 mpg (US)
Originally Posted by kitaimdao View Post
I think you can correct and modify entries.
Yes, I know we can correct/modify our own fuel log entries and garage info. What I meant by "current garage entries" was the make and model info for all vehicles... sorry bout that(head and fingers not cooperating).
...standard names, such as, "S-10"
The 3 versions I listed will yield different results when you search. At least with my truck, people list it all sorts of ways
I was thinking that if a make and model drop menu was available, then it would be standardized. And, expanding on what I said earlier, maybe make it mandatory to update the make and model parameters with a standardized drop menu with your next fuel log, then you would only be prompted to update info every 1-2 years(kinda like they do at our local library to make sure your info is up to date)....
I haven't really searched other makes and models so I'm not sure if it is even an issue for other folks.
