Old 07-17-2009, 08:45 AM   #193 (permalink)
mhmitszach
Iwishthiswasamanual - '98 Ford Escort ZX2
90 day: 32.95 mpg (US)
Originally Posted by Tygen1 View Post
Ok, got the SG last night. Here's some observations from this mornings drive to work. (be aware this is not calibrated, just inputed engine size and fuel tank size and drove)
TPS at 55 mph is between 19-21, water temp was between 209-218, IAT between 103-113, GPH at idle between 13-19 but usually 15-16, MPG during the pulse is around 25 and coasting between 200-500mpg. It was pretty cool out this morning, so we will see what tonight is....
The TPS is still usually pretty close even if its not calibrated. If you never saw 22 or 23 at 55 mph, your car is definitely running better.
My water temp, since removing ac and the partial under tray blowing away, has only ever peaked at 190. I just haven't had the time or resources to make a new under tray.
Hmm. I hardly try the pulse and glide technique.
My parents keep needing my car to run to down for random things, and they just can't seem to even pull 30 mpg. 0_0
