Originally Posted by MazdaMatt
Bump starting does not have to be hard on your engine. Even the term "bump start" makes it sound like the wrong technique. When i bump start there is NO thrashing of the engine or the occupants of the car. Put it in fifth, let the clutch half way out quickly and push it back down quickly. This will get it turning with the least friction. Tap the gas peddle to bring the revs up while it is starting itself and then let the clutch out again. Easy, smooth, friendly on your clutch and engine.
Exactly! Just let the clutch and flywheel kiss to get the engine spinning. Shouldn't be any harder/rougher than any other shift if done properly.
