Old 07-16-2009, 09:18 PM   #11 (permalink)
My Goal: 35 MPG All Day
RandomFact314's Avatar
1NZ-FE (Year 1) - '05 Scion xA RS 2.0
Last 3: 34.02 mpg (US)
1NZ-FE (Year 2) - '05 Scion xA RS 2.0
90 day: 33.32 mpg (US)
1NZ-FE (Year 3) - '05 Scion xA RS 2.0
90 day: 35.32 mpg (US)
1NZ-FE (Year 4) - '05 Scion xA RS 2.0
90 day: 34 mpg (US)
1NZ-FE (Year 5) - '05 Scion xA RS 2.0
90 day: 26.87 mpg (US)
1NZ-FE (Years 6,7,8) - '05 Scion xA RS 2.0
90 day: 28.6 mpg (US)
1NZ-FE (Years 9,10,11) - '05 Scion xA RS 2.0
90 day: 27.8 mpg (US)
1NZ-FE (Years 12,13,14) - '05 Scion xA RS 2.0
90 day: 29.13 mpg (US)
Yeah it may cause a little extra wear on some parts of the car but you know the engine is doing great driving so smoothly all the time. I don't think that hypermiling is all that bad because people are still doing it.
Old 07-16-2009, 10:16 PM   #12 (permalink)
roflwaffle's Avatar
Camryaro - '92 Toyota Camry LE V6
90 day: 31.12 mpg (US)
Red - '00 Honda Insight
Prius - '05 Toyota Prius
3 - '18 Tesla Model 3
90 day: 152.47 mpg (US)
Originally Posted by RobertSmalls View Post
John, a straw man, is a badly misinformed hypermiler practicing a few bad and a few good techniques. He pays too much for car repair, ignoring options like his neighbor the backyard mechanic who can install a junkyard tranny for $500. He has the worst of luck with cars, and his experiences do not reflect those of the ecomodder community as a whole. On the balance, Ecomodding is rewarding, both financially and in less tangible ways.
+1!
Iono if it's just me, but $600 for tires that only last 10k miles, and the like, is John's problem, not attempting to drive efficiently. For that price and can get a ~50k mile treadlife set installed on all three autos I own.
Old 07-16-2009, 10:46 PM   #13 (permalink)
Lord Vader - '15 BMW i3 REx
90 day: 35.06 mpg (US)
Yeah well, those of us silly enough to buy cars that require a low profile tire don't always have it that good. :P
At 24k miles, the tires on our Mazda5 mini-minivan are on their last legs with excessive inner shoulder wear despite being inflated to the max most of their life. Oh well, it doesn't handle like a minivan either, so I won't ***** too much.
Old 07-17-2009, 07:32 AM   #14 (permalink)
chuckm's Avatar
Exploder - '02 Ford Explorer xlt
Rolla - '02 Toyota Corolla ce
90 day: 44.43 mpg (US)
Inflated to sidewall max, my tires have been holding up like champs. Tread centers look fine.
I'm not having any auto tranny problems (engine on, tranny neutral coasting).
Snax, you may want to get your alignment checked.
"Jesus didn't bring 'Natty Lite' to the party. He brought the good stuff."
Old 07-17-2009, 08:40 AM   #15 (permalink)
Ditto.
Old 07-17-2009, 11:10 AM   #16 (permalink)
2k2Prot5 - '02 Mazda Protege5
90 day: 33.82 mpg (US)
ditta on alignment... inner edge wear is NOT a normal thing.
To save your synchros, don't jam it into gear when you're about to start. Press gently and let them come up to speed. Rev-match always between gear shifts. Also, low-viscocity transmission fluids are well known in the racing community to reduce the life of your synchros.
Bump starting does not have to be hard on your engine. Even the term "bump start" makes it sound like the wrong technique. When i bump start there is NO thrashing of the engine or the occupants of the car. Put it in fifth, let the clutch half way out quickly and push it back down quickly. This will get it turning with the least friction. Tap the gas peddle to bring the revs up while it is starting itself and then let the clutch out again. Easy, smooth, friendly on your clutch and engine.
High speed turns are also good for FE and bad for tires. Personally, i use low-profile 16" tires with a fairly low UTQG and an aggressive rain tread. Not the best for longevity or rolling resistance... hard turning resuts in more shoulder wear on my tires.
The Following User Says Thank You to MazdaMatt For This Useful Post:
j12piprius (03-26-2014)
Old 07-17-2009, 12:34 PM   #17 (permalink)
Moderate your Moderation.
90 day: 45.22 mpg (US)
I've run overinflated tires for years... I mean seriously over inflated... and probably over loaded, as well. Still haven't had problems with uneven wear, and I've got like 15-20 cars under my belt.
(I swap tires between cars)
Old 07-17-2009, 02:17 PM   #18 (permalink)
chipsndukes's Avatar
chipsndukes - '96 Toyota Tacoma
90 day: 31.37 mpg (US)
Originally Posted by robchalmers View Post
I'd agree bump starting each time will do damage - check engine mounts too as they take a kickin.
I agree. I've been working on different techniques that don't slap the engine around as much, maybe someone can give some input...
As above riding a clutch is just bad technique. if you want to save the clutch, just straight shift without the clutch on upshifts by matching revs.
So the only way to do a high speed pulse and glide without wrecking the synchros or throwout bearing is to leave the engine on, and match engine speed when going back into top gear?
Thanks,
Chipsndukes
Old 07-17-2009, 02:28 PM   #19 (permalink)
roflwaffle's Avatar
Exactly! Just let the clutch and flywheel kiss to get the engine spinning. Shouldn't be any harder/rougher than any other shift if done properly.
Old 07-17-2009, 02:34 PM   #20 (permalink)
Hypermiler
PaleMelanesian's Avatar
90 day: 69.2 mpg (US)
PaleFit - '09 Honda Fit Sport
Wagons
90 day: 44.06 mpg (US)
'zactly. I can do bump-starts that my passengers don't even notice.
hypermiling transmission
Some Hypermiling techniques denounced by AAA Lazarus Hypermiling / EcoDriver's Ed 135 04-17-2011 04:07 AM
are there race style driving techniques for hypermiling? spyghost Hypermiling / EcoDriver's Ed 12 08-07-2008 11:16 AM
