Old 07-18-2009, 04:24 PM   #198 (permalink)
mhmitszach
Iwishthiswasamanual - '98 Ford Escort ZX2
90 day: 32.95 mpg (US)
If I find tools over and my girlfriends house, I might go to the junkyard tomorrow to get air dam.
My idle tps is 16.
You still have a lower tps than I do. On a flat road at 55, it is at least 21. Sometimes, when it's running good, it will stay around 19-20 though.
I really need to remake under tray. I just haven't had time.
My water temp used to run the exact same way pre a/c removal.
I'm going to try coasting more. That is definitely the hardest technique to make stick. It makes driving places a lot longer.
My belt squeel is slowly getting worse. Any ideas to make it tighter? I mean, my belt tensioner is pretty much shot.
Also, adding seafoam to crankcase seems to have helped with the rough idle. It doesn't shake nearly as bad.
