Because I am a dork (and most of us here are) here is an Idea for you since you are now past the one year mark. If you keep an excell or similar spread sheet for your personal viewing instead of using date format mm-dd-yyyy record your fillups by day of the year such as day #165 for May 14 and every time you change years track it as a new data set so the years run concurrent and you will really begin to notice improvements or decreaces as technique and tuning battle age and wear, other factors such as your temperature graph would then be ruled out as constants. congrats and good luck
