Old 07-21-2009, 02:48 PM   #33 (permalink)
gascort
gascort's Avatar
Gascort RIP - '93 Ford Escort Wagon
90 day: 43.01 mpg (US)
WifesCruze - '11 Chevrolet Cruze LT
90 day: 31.1 mpg (US)
Noxman, I'm unsure on the thickness; it's probably about 3mm I'd guess. Thinner would be better, I think, because it would flex easier.
Phil - I have some reflective tape I've been meaning to add. Eventually I want to put some taillights out there. Luckily most seem so distracted by it in parking lots so far that they're more likely to run into something else!
One thing I noticed the other day - it is bad in the rain; water from (I guess) under the car sprays up on the underside and makes it opaque to all but headlights. This will hopefully be improved when I clean up the bottom and the sides of the car though.
Gasoline, Wind, Solar, Gravity Hybrid-to-be! http://www.scientificmethodfueleconomy.blogspot.com/
