Old 02-27-2008, 08:33 PM   #11 (permalink)
RH77
Depends on the Day
RH77's Avatar
Teggy - '98 Acura Integra LS
Sports Cars
90 day: 32.74 mpg (US)
IMA - '10 Honda Insight EX
90 day: 34.76 mpg (US)
Tessie - '06 Acura TSX Base
90 day: 28.2 mpg (US)
First: Wear a decent hat/cap. Most heat is lost through the top of your head.
Layers, layers, layers. Get warm first, and head out. Don't sweat while heating-up: evaporative cooling could occur.
Extreme example: Make your own heated seat with a $10 inverter plugged into the cig-lighter and a heating pad.
My hands get cold first (history of frostbite). I make a fist inside gloves with fingers to let the palms heat the fingers...or sit on my hands and steer with the knees. Whatever it takes to keep them warm.
Note: most of this was done in -10F Weather lately.
The hardest part: not turning the temp knob to the warmer setting until the coolant is up to the proper temp...
RH77
“If we knew what we were doing, it wouldn't be called research” ― Albert Einstein
_
_
