Originally Posted by MPaulHolmes
Joe's controller had been going from 0 to 80 amps instantly, and then smoothly from 80 amps on up. I finally figured out what was going on! Ya! Long story short, it's easy to fix. In fact, I don't need a new coupler! The banging I kept feeling was the immediate transition to 80 amps. I just never had a motor current monitor, so I didn't know what it was.
I tried out the code with the extra line in it, and wow what a difference!
the car is a lot smoother from a stop now and the throttle control actually feels a little better. I guess when you consider that before we gained almost another 20% usable range of throttle, it's quite a difference.
The motor amps can be controlled down into the single digits and I set the max throttlePos to 470. This actually correlates to an output of 487amps (according to the meter i have, anyway) and doesn't trip the overcurrent protection. When I was playing around with it before, 490 amps started to trip the overcurrent protection.
Good work Paul!
