02-28-2008, 09:31 AM
#10 (permalink)
You're less likely to have a blowout from high inflation pressures as far as temperature is concerned - higher pressure = less heat build up. You may be at more risk of a blowout from hitting a pothole. (Though I haven't heard of anyone having a blowout from that situation either.)
And if you're a good driver, you don't have to worry about regaining control, 'cause you're not going to lose it in the first place!
