This was the Hot Air Intake before this new modification. I have modified it 3 different times so far.
I modified this Hot Air Intake in the photo from Cold Air Intake modification.
I like the idea of straight up off the intake on the new modification. I don't know if I will get more MPG off it as set up or if I will get more completely covered with only hot air from the engine. I think from less restriction I should get some gains. What are your constructive thoughts or suggestions to get more out of the Intake?
