Originally Posted by mcudogs
I will add the diodes to the next version controller board. The other way to cut out some of the interference is to make sure that you don't run low voltage signal wiring close and parallel to high voltage / current wiring.
My potbox wiring does run pretty close to the motor loop wiring, but they don't cross and the two actually do run mostly perpendicular.
Could the diodes be added to the wiring on the potbox connectors (in these beta testing cases where the boards are complete already) and still be effective? They're easily accessible...
I switched back to 16 Mhz and it's working well, but I could add whatever components are required and see if I can get it to freeze up again. I don't miss the 8khz whine though. They have that rubberized asphalt stuff on the highways here in phoenix - virtually zero tire noise. Combine that with nearly zero motor noise and all you can hear is the whir of the vent fan. It's beautiful.
