Old 08-07-2009, 02:54 AM   #26 (permalink)
orange4boy
orange4boy's Avatar
The Golden Egg - '93 Toyota Previa DX
90 day: 31.91 mpg (US)
Chewie - '03 Toyota Prius
90 day: 57 mpg (US)
The Spaceship - '00 Honda Insight
Plumb it is.
I had a piece of 1/8" plexi around so the end is filled with the table saw shaped piece. The sides are black coroplast for now but I think I will pop in the twin wall lexan when I get some more. The bottom is not filled yet but I have some "clear" coroplast which will probably fill that function
Construction details... Drilled and tapped for 8-32 pan head stainless machine screws.
I'm not totally satisfied with the look of this. I think it needs a radius at the end at the top corners and along the lexan seam. I can fix this later. I also want to make a side detail that reflects curves of the stainless scimitar panels.
There she is 90% done and driveable. As a fun design accident, the trailing edge has a trip angle to it.
Wake area reduction is approximately 7 sq feet. from about 28 to 21 so almost 1/3 reduction, if my math is right. It sure will be interesting to see how that feels at highway speed. Who knows what the un-modded bottom half does to the air. We shall see.
Vortex generators are old tech. My new and improved vortex alternators are unstoppable.
"It’s easy to explain how rockets work but explaining the aerodynamics of a wing takes a rocket scientist.
