Old 08-10-2009, 06:42 PM   #13 (permalink)
Matt Herring
Matt Herring's Avatar
Bone's 2010 Prius - '10 Toyota Prius Black
90 day: 56.78 mpg (US)
I just did a quick lookup on avg. temps for Sheffield so that's where I got the 65 degrees F from...you would have a much better idea actually being there. Maybe an easy to install/remove grill block would suit you best if you needed to remove it on hotter days.
I use foam pipe insulation that squeezes nicely into my front grill slots and is easily installed/removed in under a minute. Maybe something that would work for you...good luck!
