Originally Posted by Matt Herring
I just did a quick lookup on avg. temps for Sheffield so that's where I got the 65 degrees F from...you would have a much better idea actually being there. Maybe an easy to install/remove grill block would suit you best if you needed to remove it on hotter days.
Sorry bit of a crossed wire situation here. We use degrees celsius here, so when I first saw "65" it's like you reading the local temp to being 150 degrees F! No way we get that hot here in the UK
Anyway. Grill slats very narrow, so might be hard using foam pipes, but I'll do a bit of research. Thanks again!
