Old 08-11-2009, 11:00 AM   #43 (permalink)
sawickm
ReVolt Enthusiast
Excellent Job !!!
Hi Adam,
I want to thank you for sharing that information on your High Performance Motor Controller.
Like Eric, I too am interested in a performance version of Paul’s Revolt Motor Controller. I would be very interested in purchasing a Kit, or just the set of PCB's for your High Performance Motor Controller !!! The supplier for the heat sinked case is not a problem, a new case could easily be designed around you set of PCB’s.
Also are you using the same Hall Sensor in Paul’s Cougar Controller (LEM HASS 300-S) ??? Will it work with the higher current output of your High Performance Motor Controller ?
Thanks again,
Mark
