The headlights are rated at 12v @ 55w. So if i multiply that by two, I should only be reading at 110w at lo-beams.
Further testing shows, when i hook up the DMM to the actual passenger side headlamp in series, its only drawing about 4amps (x2 headlights = 8amps x 11.8v = 94w)
But when i hook it up to the battery, it measures 9amps (x2 headlamps = 18amps x 11.8v = 212w) (this is with only 1 headlight attached, i removed the driverside headlamp). But I guess it just means its also measuring all of the other electrics as well?
Which would be the more accurate reading? From the headlamps (94w) or from the battery (212w)?
