Old 08-16-2009, 12:33 PM   #1 (permalink)
pgfpro
In Lean Burn Mode
pgfpro's Avatar
MisFit Talon - '91 Eagle Talon TSi
Team Turbocharged!
90 day: 63.95 mpg (US)
Warlock - '71 Chevy Camaro
Fe Eclipse - '97 Mitsubishi Eclipse GS
Future mods list.
I decided to make a list of future mods/progress with my turboed Sol.
My Game plain.
1) Run with the windows up this time and run when its cooler weather so me and the wife will be comfortable. Edit Increase tire pressure from 40psi to 50psi.
2)Change the light load fuel cells with my engine management system from
15.5 A/F to 17:1 A/F ratio.
3)Run my home built lean burn spark plugs with an A/F ratio around 20:1
This mod I'm the most interested in. I have done some testing with it but nothing more then a few miles. With these plugs the engine won't miss fire at 20:1 at light load. But I'm not sure if the BSFC will be any better then the 17:1 A/F ratio.
4)Front aero mods. Cover up 90% of the grill and running light holes.
5)Kamm back and wheel well skirts and pizza pan hub caps.
All mods will be with the same gas station fuel and the same route of 144miles.
I will also be doing these at 65mph because any slower I will get ran over
Pressure Gradient Force
The Positive Side of the Number Line
