Old 08-17-2009, 12:41 PM   #7 (permalink)
pgfpro
In Lean Burn Mode
pgfpro's Avatar
MisFit Talon - '91 Eagle Talon TSi
Team Turbocharged!
90 day: 63.95 mpg (US)
Warlock - '71 Chevy Camaro
Fe Eclipse - '97 Mitsubishi Eclipse GS
Originally Posted by janvos39 View Post
Pro, how do you make sure that the rich mixture gets into the prechamber?
It basically works by doubling the surface area around the electrode. But at the same time keeping this area confined. The fuel tends to collect in this chamber due to the low pressure the chamber creates.
So far it has worked as far as there isn't any miss fire at 20:1. But I don't have a clue if it will work by increasing fuel mileage?
Time will tell?
Pressure Gradient Force
The Positive Side of the Number Line
