Thread: Solar Roof
Old 08-18-2009, 02:51 AM   #61 (permalink)
orange4boy
orange4boy's Avatar
The Golden Egg - '93 Toyota Previa DX
90 day: 31.91 mpg (US)
Chewie - '03 Toyota Prius
90 day: 57 mpg (US)
The Spaceship - '00 Honda Insight
Plexiglass is a brand name for acrylic. You can glue them together but you will need a cement designed for acrylic bonding. Weldon 3,4 or 16 will work, the 3 and 4 are water thin and have to be applied with an applicator (the 3 dries faster than the 4) and the 16 has a syrupy consistency. There is also a product called "plastic welder", I don't remember who makes it (maybe Devcon?) that would also work and probably be easier for you to find for this single project. You may be able to find the pthers locally, look in the yellow pages under plastics and see if you have any listings. Good luck, Skip
Or, you might try glazing tape. It's a butyl strip, like tar, on a roll, used to install sealed units to a window sill. It happens to stick well to acrylic and is flexible. Unlike the above Weldon products, It should also be non permanent if you ever need to take it apart again, with a little heat (a warm day in the sun) and some patience you should be able to pry it apart.
See, we can get back on track.... eventually.
Vortex generators are old tech. My new and improved vortex alternators are unstoppable.
"It’s easy to explain how rockets work but explaining the aerodynamics of a wing takes a rocket scientist.
