Old 08-21-2009, 12:05 PM   #1 (permalink)
GoodOak
Pickup Fuel Meiser
Blackline - '09 Nissan Frontier King Cab SE V6
Jetta - '11 Volkswagen Jetta Sportswagen TDI
partial grill block: what do I need to consider?
OK, I'm ready to move forward and try out a partial grill block. I could do a test run with chloroplast (where is the best place to get this?) and if it works out try something more permanent with plexiglass cut by my local glass shop. Or maybe skip the test run and save some time and just get the permanent one made?
So the grill block improves aerodynamics and helps the engine warm up faster. But how do I determine if my engine will overheat as a result? I have a ScanGuage, should I be keeping track of the engine temp? If so, what range should I be looking for?
Frank
RIDE A BIKE!: "If by tomorrow, every gas guzzler on the road were replaced by Priuses, we would still have the same gridlock, accidents, deaths, injuries and the same pressures to put more asphalt, strip malls and subdivisions." --Thomas Smart: SuperCommuter
