Old 08-21-2009, 12:05 PM   #1 (permalink)
Pickup Fuel Meiser
Blackline - '09 Nissan Frontier King Cab SE V6
Jetta - '11 Volkswagen Jetta Sportswagen TDI
partial grill block: what do I need to consider?
OK, I'm ready to move forward and try out a partial grill block. I could do a test run with chloroplast (where is the best place to get this?) and if it works out try something more permanent with plexiglass cut by my local glass shop. Or maybe skip the test run and save some time and just get the permanent one made?
So the grill block improves aerodynamics and helps the engine warm up faster. But how do I determine if my engine will overheat as a result? I have a ScanGuage, should I be keeping track of the engine temp? If so, what range should I be looking for?
Frank
RIDE A BIKE!: "If by tomorrow, every gas guzzler on the road were replaced by Priuses, we would still have the same gridlock, accidents, deaths, injuries and the same pressures to put more asphalt, strip malls and subdivisions." --Thomas Smart: SuperCommuter
Old 08-21-2009, 09:41 PM   #2 (permalink)
Hi,
You can buy Coroplast at sign maker shops. You won't need very much -- I would even just try it out using duct tape. Yes, start keeping track of the coolant/water temperature on the SGII. It should be pretty constant near the temp for the thermostat -- 180F or 190F are common, I think?
Check with others with pickup trucks -- I think you'll be able to block all three of the upper openings.
Permanent Aluminum Grill Block and Belly Pan Markmysite EcoModding Central 41 02-27-2014 09:22 PM
Lower Grill Block 2005 Honda Civic Arminius EcoModding Central 12 10-04-2011 12:31 AM
How to build a partial Grill Block for a Caravan/Town & Country popimp DIY / How-to 21 12-18-2009 03:14 PM
Spring mounted Grill Block cfg83 EcoModding Central 32 04-19-2009 06:00 PM
My try at a partial grill block bhazard Aerodynamics 15 04-30-2008 10:09 PM
