Old 08-25-2009, 09:35 AM   #11 (permalink)
MetroMPG
90 day: 51.82 mpg (US)
Originally Posted by Christ View Post
You wouldn't have a visual of the rear view anywhere stashed away, would you? Would you liken it to looking through a rear window that had louvers on it?
I believe Phil had just the one "step" in his bed cover for rear vision (plus one at the top for the center mounted brake light).
You can sort of see it here:
From: http://ecomodder.com/forum/showthrea...ding-1280.html
So you can't see through plexi when it's at the right angle for a Kamm... same with lexan.
I'm fairly sure I asked basjoos about the rear visibility through his boat tail, and he said it was OK.
