Old 08-25-2009, 03:03 PM   #24 (permalink)
AmpEater
WHoops! Not intentionally. NO, that was just me mis-reading your post. I thought I read "every .1v drop".
That leaves the Flea with ~25 hp @ 12v with a 10hp/1v drop from 14.5 v.
Which is of course, still not likely. The test vehicle related to that statement probably had a billion horsepower to start with.
OK, good point, that info is useless without the original power of that engine. Assuming it was 300hp originally that works out to 3.33% power loss per volt.
It is pretty common in the racing world to run a 16v battery without an alt. Under the same sag as a normal battery that works out to ~14.66v, perfect. In that situation horsepower is all that matters, so clearly that extra voltage makes a difference.
