Old 08-26-2009, 05:39 PM   #11 (permalink)
RH77
Depends on the Day
RH77's Avatar
Teggy - '98 Acura Integra LS
Sports Cars
90 day: 32.74 mpg (US)
IMA - '10 Honda Insight EX
90 day: 34.76 mpg (US)
Tessie - '06 Acura TSX Base
90 day: 28.2 mpg (US)
Originally Posted by micondie View Post
I think that if you did an A-B-A test between WAI and CAI in which you controlled the acceleration to match it between tests you would find no advantage to WAI.
That my 2 cents
Mike
I accidentally had a single-blind test that confirms it for my vehicle...
Under similar weather conditions, an early version of a WAI broke loose and started to inhale cooler air under the front bumper (not freezing cold, but in the 50F-75F range). This was before the SG -- an OBD chip documented the scenario.
It was a couple of weeks before I popped the hood and found the problem. I would like to say that I was accelerating similarly, but I only have incremental speed readings to compare. I filled up and noted the results. With the rough data presented, the conclusion was that the cooler air decreased FE.
YMMV.
RH77
“If we knew what we were doing, it wouldn't be called research” ― Albert Einstein
_
_
