Old 08-28-2009, 01:31 AM   #65 (permalink)
Christ
Moderate your Moderation.
90 day: 45.22 mpg (US)
Strip down your knuckles and weigh them... I think they're about 20lbs stripped, and might fit in a flat rate... I'll have to strip one down and find out.
The only part that's different is the hub itself... I'll pull the upper A arms, lower control arms, calipers, rotors, caliper bracket (you'll want to use your original brake stuff anyway) and they might fit in a flat rate, maybe. If not, probably about 25lbs x2 from 16947 to you.
