Ok, so project Kammback was killed by the girlfriend
Other ideas that I'm currently planning/working on:
1)Installed alternator disable switch
2)Build custom solar panel and stick it on my trunk (there is turbulence in that area anyways so it shouldn't hurt with aerodynamics. And since project kammback was killed, this is my replacement). In the mail waiting for arrival.
3)Deep cycle battery in the trunk
*Should i use only the deep cycle? or wire it in parallel to the main starting battery?
4)(maybe) Alternator delete
5)Power steering delete
6)Rear wheel skirts
7)Front grille block
8)Underbelly Tray
9)skinnier LRR tires
