Old 08-29-2009, 09:34 PM   #46 (permalink)
elhigh
Master Novice
elhigh's Avatar
Josie - '87 Toyota Pickup
90 day: 29.5 mpg (US)
90 day: 49.47 mpg (US)
Originally Posted by Dieselman View Post
That's not true vacuum as the servo has a bleed off when the brakes are not being used. A pipe to a MAP sensor or similar is true vacuum as it is a dead end with no leak off.
Are you sure about that? My system has a check valve to hold vacuum in there when I'm not using brakes. I T'd into that very line to hook mine up, it pulls a really deep vacuum. Pegs the needle on the top end, decel in gear.
