Old 08-31-2009, 08:56 PM   #35 (permalink)
droptail
Originally Posted by Clev View Post
I'd say this is pretty much what you're looking at. He has a full-size Chevy truck, so the motor would probably clear the bed (or at worst, maybe he'd have to put a little hump in the bed over the motor), and beyond that, it's a question of turning the driveshaft into two driveshafts with the motor between and the various ends hung so they're at the correct angles.
As far as freewheeling the motor when it's not being used, I remember from the EVDL that there's no problem doing this as long as you don't overspeed it. You can check with Jim Husted on the EVDL, but I'm pretty sure that the shafts on the ADC can handle the torque from the engine.
Again, thats what I'm looking for as far as strength and free-wheeling, thanks.
Your reference incorporates a bed mount with chain drive I believe? There is room for a straight inline driveshaft install. I am concerned about allowing to move with the suspension, verses a rigid frame mount.
