Originally Posted by SVOboy
I believe I mentioned that before but expressed desire to use the insight twigs, since they're smaller and more insighty. Plus, one of my crx axles is going bad so either way I'd need to spend the money.
BTW, figure out shipping on those knuckles and I'll pay you money! Try to make it cheap though
Gimme an address in PM, and I'll weigh one up this weekend.
In the mean time, how much is the weight difference between the DX axles and the Insight axles? have you checked under the boots to see if you can swap the DX outers onto the Insight's shaft?
All these things are probably going to be much easier than (albeit not as cool as) swapping your hubs to HF/std hubs, which also come with smaller brakes, something you should be aware of when adding more weight to your car.
Far be it from me to be concerned about someone else's safety
I'll still see about getting those knuck's to ya.
