Old 09-02-2009, 03:55 PM   #16 (permalink)
RH77
Depends on the Day
RH77's Avatar
Teggy - '98 Acura Integra LS
Sports Cars
90 day: 32.74 mpg (US)
IMA - '10 Honda Insight EX
90 day: 34.76 mpg (US)
Tessie - '06 Acura TSX Base
90 day: 28.2 mpg (US)
The switch could be a simple key switch by which the driver holds the key to deactivate. Plus, who hasn't EOC'd and re-started in a corner It gets lighter -- I guess, just adjust as necessary (of course do not attempt unless thoroughly practiced).
So, I'm not clear on the belt removal problem...
I have an ideal situation where there's no serpentine involved and the one belt for the PS is the outer-most pulley set. In the rare event that my Wife drives the car, I can pop the belt back on.
Is it possible to just remove the belt and run with it?
RH77
“If we knew what we were doing, it wouldn't be called research” ― Albert Einstein
_
_
