Those plastic wheel storage covers would be perfect to use for something like this. I have wanted to do this for a while now. Snow might be murder on it but perhaps not.
Start with a two piece plastic cover, easily separated flange/seam radially along the middle of the cover. You would have to attach to the back of the spindle. simple!
As a side benefit these would keep your wheel wells clear of all that road gunk that always collects under there: the main reason for the inevitable rust in these areas. I just cleaned out my rear wells today. Yuck!
Would reduce the aero drag but still leave a gap for the air to push around.
Vortex generators are old tech. My new and improved vortex alternators are unstoppable.
"It’s easy to explain how rockets work but explaining the aerodynamics of a wing takes a rocket scientist.
