Old 09-05-2009, 02:38 AM   #43 (permalink)
orange4boy
orange4boy's Avatar
The Golden Egg - '93 Toyota Previa DX
90 day: 31.91 mpg (US)
Chewie - '03 Toyota Prius
90 day: 57 mpg (US)
The Spaceship - '00 Honda Insight
I have been doing brake drag reduction work and pre winter stuff while the weather is still good.
I discovered the rear drums on the Previa drag all the time due to the automatic brake adjusters which are actuated by the e-brake. DISABLED!
I can adjust by hand, thanks. Next week I'll do the seals on the front right caliper and lube both L+R sliders with moly.
This has made a big difference in my coast down. Hard to test aero mods if your brakes are sticking!
While I was down there I found a rust spot crawling up from the wheel well corner. I cleaned out all the gunk from behind the plastic wheel well panels then sanded out the rust and did a spot paint repair on the corner. I then undercoated the places they missed at the dealership. All day affair.
I still have to finish the lower part of the kamm but now I'm already thinking about the folding boattail addition to the kammback.
Help me, I'm drowning in projects!!!!
Vortex generators are old tech. My new and improved vortex alternators are unstoppable.
"It’s easy to explain how rockets work but explaining the aerodynamics of a wing takes a rocket scientist.
