I'm thinking about installing a TC lockup switch in my Previa. Were would one find the solenoid (It's not in the wiring diagram or Haynes manual I have)
Since I may forget to switch it off, what is the effect of having the TC locked up in gears lower than 3+4? Does it stall out if you try to stop? Why not lock up at lower speeds?
I live in hilly country with a low speed limit and I am hoping that TC lockup will help FE on those steep hills and the flats we do have. I'm always in 2+3 and it rarely locks up.
Vortex generators are old tech. My new and improved vortex alternators are unstoppable.
"It’s easy to explain how rockets work but explaining the aerodynamics of a wing takes a rocket scientist.
