Makeshift adapter plate is mostly done. Made it out of 1/8 inch steel. I used the doors from my Dodge B350 cargo van that separated the driving compartment from the cargo area. Even that thin stuff is no fun to cut with a sawzall. I think I will call that tool a "sawzsome" from now on. I need to run down to the farm supply place again and get a holesaw to cut the hole for the motor shaft. I also pulled out all the electrical stuff from the golf cart yesterday. I was thinking of throwing all that stuff into the car just to see if it works, but it looks so complicated.....
