Old 09-08-2009, 01:01 AM   #13 (permalink)
orange4boy
orange4boy's Avatar
The Golden Egg - '93 Toyota Previa DX
90 day: 31.91 mpg (US)
Chewie - '03 Toyota Prius
90 day: 57 mpg (US)
The Spaceship - '00 Honda Insight
2nd run complete. Working great.
Observations:
TC lock does not engage in first gear. The safety there is still working even with the bypass switch. Not really a problem since I spend very little time in first. My driveway will have to be slushed. Fitting, really.
Second gear is pretty long so I have to start unlocked but I can get locked at about 40Kph / 25mph. A little below that on the flat and it needs to be going about 45kph / 30mph to do the hills here without bogging. (I'm not sure of the rpm shift points yet.)
Shifting into 3rd is not harsh at all under the conditions I tried it (slight up grade). There is a little "mount bounce" after the shift but it's very mild.
I believe OD is really just fourth gear so that has to be disengaged or it will shift into OD too soon after 3rd. The tree is really a pain for this type of driving so I'm dreaming of finding a suitable shift lever to replace the original.
OK, that's the last smiley.
You can see the lockup switch elegantly taped to the tree, my digital vac gauge (thanks Vtec-e) and my temporary, tacky low tech tach.
I like the washer fluid button in this pic. It's all "OH...OH...pick me...pick meeeee."
I need to figure out which of these wires is for solenoid one and two. I already know the green/yellow is #3
Anyone? ...... Anyone? ..... Bueller? ..... Bueller? .... Bueller?
This just shows how easy it is to find on the Egg. (Small mercy) The ECU is the ONLY thing engine-wise that's easy yo get to.
Vortex generators are old tech. My new and improved vortex alternators are unstoppable.
"It’s easy to explain how rockets work but explaining the aerodynamics of a wing takes a rocket scientist.
The Following User Says Thank You to orange4boy For This Useful Post:
ECONORAM (07-11-2013)
