Old 09-08-2009, 06:26 PM   #1 (permalink)
IsaacCarlson
eco....something or other
wood hauler - '91 Ford F-250
Team Pontiac
90 day: 26.69 mpg (US)
Rav - '06 Toyota Rav4 Base
90 day: 26.52 mpg (US)
knock sensor question
my chilton book says the sensor provides 8-10 volts to the ecm. when knock is detected that current is cut and timing is delayed up to 20 degrees. if i unplug the sensor that will cut voltage and timing will be delayed 20 degrees correct??? "loss of signal to ecm will cause constantly retarded timing"
1991 F-250:
4.9L, Mazda 5 speed, 4.10 10.25" rear
