Old 09-08-2009, 08:06 PM   #281 (permalink)
RobertSmalls
Left Lane Ecodriver
RobertSmalls's Avatar
Prius C - '12 Toyota Prius C
Originally Posted by SVOboy View Post
- horn: crx has two horns, each with two wires. Insight has one with one wire. Not sure how to fix this part yet, I might just get an insight horn, it's probably lighter anyway.
Apply battery voltage to each of your CRX horns to determine which one sounds better. One is low tone, one is high tone. Take the one you like, and run one of its wires to ground (e.g. at the horn mounting bolt) and the other wire to the horn wire. I suspect horns are non-polar, but I could be wrong.
