Thread: high idle cold
Old 09-08-2009, 10:46 PM   #3 (permalink)
RH77
Depends on the Day
RH77's Avatar
Teggy - '98 Acura Integra LS
Sports Cars
90 day: 32.74 mpg (US)
IMA - '10 Honda Insight EX
90 day: 34.76 mpg (US)
Tessie - '06 Acura TSX Base
90 day: 28.2 mpg (US)
Around 2-grand on a super-cold start.
There may be something amiss with a control valve of sorts (idle-air, etc.) On mine, it's a wax-based internal that melts at "warm" and allows proper intake flow. If it's solid, the air is bypassed, allowing a higher idle.
EDIT: Since you have a carb, make the appropriate adjustments with the set-screws.
Just jam it into 2nd and roll with it right away -- idling is your enemy. I do that with the automatic and let the extra idle carry the car. If you don't have some sort of engine block heater, I would get one now.
RH77
“If we knew what we were doing, it wouldn't be called research” ― Albert Einstein
_
_
