Old 09-09-2009, 01:05 PM   #284 (permalink)
Funny
Funny's Avatar
Eco-Fit - '13 Honda Fit Base
90 day: 37.06 mpg (US)
Originally Posted by SVOboy View Post
I'm also excited to finally see the engine in the car for good. I just finished wiring in the engine bay harness from the insight. Most of the wires are colour-coded the same way, but naturally there are a few issues:
Pictures? I may be asking too much, you are rather busy...
- headlights: the insight has integrated low-high beams instead of separate bulbs, but I just split the ground and routed the wires separately, so I hope that works.
You may with to upgrade this wire with a lower gauge to handle the additional amperage that will be traveling down it, if I'm not mistaken. Unless I misunderstood you, the high and low beams would be going though the same wire. I'm not sure if the high and low beams would be on at the same time for any appreciable amount of time, but if they were, that might just be too much for it. Just a thought.
Anyway, right now I'm going to hit to books so I can eliminate more wiring from the car since I'm starting to duplicate things and that's bad.
The more things integrated, the more things that can break. Good thinking.
American by right
Ecomodder by choice
Hypermiler by necessity
