Old 09-10-2009, 10:58 AM   #285 (permalink)
Christ
Moderate your Moderation.
90 day: 45.22 mpg (US)
Originally Posted by Funny View Post
You may with to upgrade this wire with a lower gauge to handle the additional amperage that will be traveling down it, if I'm not mistaken. Unless I misunderstood you, the high and low beams would be going though the same wire. I'm not sure if the high and low beams would be on at the same time for any appreciable amount of time, but if they were, that might just be too much for it. Just a thought.
The Insight has a dual filament bulb, so there are both high and low beams from the same bulb. The CRX has two different bulbs, so one for high, one for low.
He took the Insight's harness and split the high/low power wires to use on the high/low bulbs in the CRX.
Ben, look up the mod for all-four-on highbeams. It's great.
