This is where I found the info for my shift project.
The Free Mod Series: Part VIII Electronic Transmission Controller - Toyota Forums :: Toyota Nation
The concepts are the same for most ECT's You might need to change the wiring of the switches if the shift pattern is different and the resistors based on the resistance of your solenoids under load. I imagine that its similar though.
Vortex generators are old tech. My new and improved vortex alternators are unstoppable.
"It’s easy to explain how rockets work but explaining the aerodynamics of a wing takes a rocket scientist.
