Old 09-14-2009, 01:48 PM   #2272 (permalink)
jyanof
Joe
Originally Posted by LouMan View Post
BETA TESTERS???
I was wondering why the beta testing isn't getting posted?
not much to report...
Everyone beta testing should be posting how the controller is doing,
How it is performing,
Very well, working on the latchup problem. No thermal cutback mode problems, even in the hot AZ temps.
How many mile a day they are getting,
This is mostly a function of the number of batteries you have, but my commute to work is 15 mi round trip. I'll also drive it out for errands and stuff, the most I've put on so far in a day is 45 mi. This week I'll start driving out to the school where I coach track twice a week - that's a 52 mi round trip, so I'll be rackin up the miles.
Total miles since install,
about 1000
How the temp's are doing,
This has been previously addressed in this thread, or maybe the one in my sig. Nothing has changed. Keep in mind that others may not have the necessary equipment to get temp readings.
How the boards are holding up,
I haven't taken it apart, so I don't know. I'll be adding the over/under voltage diodes soon, so I'll check that out. It would be good to check on the mechanical integrity of everything after some real world driving.
Is there any brown spots on the power board to show if mosfet's are getting to hot,
I don't think a hot mosfet would affect the board, but i'll take a look - see above.
What kind of setup they have and what kind of performance they are getting,
See the thread in my sig for my setup
What kind of cooling & temp with that kind of cooling,
The controller is bolted to an aluminum heatsink with 3 high CFM computer fans whizzing away underneath it.
What they like and don't like,
My only comparison is the Curtis 1231c.
No more whine.
No more thermal cutback.
no more whine due to thermal cutback.
Customized throttle response.
small size
I suspect the increased capacitance reduces the ripple current on the batteries. This has to be good.
Once the latchup fix is tested, there won't be any problems...
What they did to make it more efficient.
The user doesn't have much control of this. Guess you could change the gate resistors at the risk of blowing some mosfets, but your only gain, really, is in less heat to dissipate. Right now, the controller is calculated to be 98.8% efficient at a cruising current of 200A.
Beta testers should be posting regular updates on the controller, they should be taking notes everyday on all of these perimeters & posting.
Well, speakin for myself, I'll do what I can. Performance parameters have been consistent, so I see little value in posting updates. Something new would be worth posting about.
I dont want this project to end with a thought of I got mine working you figure yours out!!!!
Ask and you shall receive
I've noticed everyone on here has been very helpful - the global communal aspect of this thread might be the most amazing part of it!
ReVolt AZ testing thread:
http://ecomodder.com/forum/showthrea...ting-9325.html
