My G5 is a 2009 XFE. My engine is the 2.2L ECOTEC, same as yours. I guess my speedo has a higher top end cuz mine's a Pontiac (The 'former' performance division), so GM is either lying to you or lying to me!
You are exactly correct. The G5 in all trim levels uses the same speedo, although the face may be a little different) as the Cobalt SS. The GS XFE will not do 140, nor will the Cobalt XFE.
It's a lot faster than my Metro. I promise you that.
