Old 09-19-2009, 05:39 PM   #387 (permalink)
SVOboy
Dartmouth 2010
SVOboy's Avatar
Vegan Powa! - '91 Honda CRX DX
90 day: 66.52 mpg (US)
Send a message via AIM to SVOboy Send a message via MSN to SVOboy Send a message via Yahoo to SVOboy
Honda used atypically small bolts for the side mount through bolts on the insight. I have about 20 bolts that would fit the rear mount which it's the only one I'm not using from the insight.
I got some from home depot but they didn't list the thread spacing so they ended up being wrong.
Anyway, I ended up finding a o2 plug and bung, but where can I get piping to make a crappy pipe to connect up my two bits of exhaust? I wonder if I can get away with just welding a few feet of straight pipe on the create back pressure and calling it a day. Thoughts?
Also, all the mounts are done, I need to shave a little off one of them but otherwise they're good. When I get the bolts in should I go ahead and tackweld the nuts to the backsides of the mounts? This seems like a good idea to me but there might be a good reason why it's a bad idea.
