Well, in the gas turbine world, for those who use diesel for fuel, it is recommended that the fuel be heated to 100 degF. Gasoline, a different animal.
"Maybe" heating gasoline from -30C to something above 0C might help a bit with combustion in keeping the cylinder temperature up - assuming you use a warm air intake in conjunction. Cold air plus cold fuel can't be the best combustion process.
