Old 09-19-2009, 11:00 AM   #11 (permalink)
toyota corolla - '99 toyota corolla ce
90 day: 38.97 mpg (US)
Originally Posted by Christ View Post
In your sig, it says 20-25 amp... I went with 20.
Oo yeah i remember adding about 5-10 amp for the radio and my second amplifier .
graphic:http://ecomodder.com/forum/em-fuel-l...vehicleid=3083
lowered -1.5 inch .
+80 pound (approximation) of audio (and draw a max of 20-25 amp approx..)(ouch for alternator !!)
Old 09-19-2009, 11:02 AM   #12 (permalink)
Moderate your Moderation.
90 day: 45.22 mpg (US)
Well, that's still counted as an audio component... and if your head unit is 10 watts per channel, unless you're using a line out (non-pre-amped) it's 210 W max output to whatever speakers that amp is running. *the term is daisy chained*
If you have an amp powering another amp, you add up the wattage of the two amps. Most head units are amplified, so you add the wattage of the head unit to the wattage of the amp when considering your total output.
Old 09-19-2009, 11:05 AM   #13 (permalink)
radio ( max 10 amp cause fuse is 10 amp ) probably more 4-5 amp (drive 2 speaker )
2 amplifier (independant )
prs-x320 2x 100 watts
prs-x220 2x30 watts
lowered -1.5 inch .
Old 09-19-2009, 01:52 PM   #14 (permalink)
Big Dave's Avatar
The Red Baron - '00 Ford F-350 XLT
90 day: 27.99 mpg (US)
Impala Phase Zero - '96 Chevrolet Impala SS
90 day: 21.03 mpg (US)
Your problem isn't in the engine compartment.
Air at -30C holds zero water and is very dense. Remember the "rho" in the road load equation? That's air density. Aero drag is proportional to air density.
Also snow and ice covered roads enforce a very non-hypermiling style of driving.
Don't blame the gas.
2000 Ford F-350 SC 4x2 6 Speed Manual
4" Slam
3.08:1 gears and Gear Vendor Overdrive
Rubber Conveyor Belt Air Dam
Old 09-19-2009, 02:29 PM   #15 (permalink)
yes you are right
air is dense .
lowered -1.5 inch .
Old 09-20-2009, 01:38 PM   #16 (permalink)
Wildfire - '96 Ford Bronco XL
90 day: 14.88 mpg (US)
Blackford - '96 Ford Bronco XLT
90 day: 20.26 mpg (US)
Y2k - '00 Honda Insight
Gen-1 Insights
90 day: 73.98 mpg (US)
Redford V10 - '01 Ford F250 Lariat
90 day: 15.64 mpg (US)
FireFly - '00 Honda Insight DX
90 day: 69.43 mpg (US)
LittleRed - '00 Honda Insight
Well, in the gas turbine world, for those who use diesel for fuel, it is recommended that the fuel be heated to 100 degF. Gasoline, a different animal.
"Maybe" heating gasoline from -30C to something above 0C might help a bit with combustion in keeping the cylinder temperature up - assuming you use a warm air intake in conjunction. Cold air plus cold fuel can't be the best combustion process.
Heat Pump Temp Lockout Settings to Gas Backup RH77 Saving@Home 3 03-11-2012 09:41 AM
Conversion idea, 2L inline 4 -> piston boosted 1.0L 2 banger? Warning....Long thread JoJotheTireMan EcoModding Central 56 06-12-2011 03:09 AM
Mini-split ductless question.. Xringer Saving@Home 50 05-25-2010 04:01 PM
Electric car heat! Liquid? bennelson Fossil Fuel Free 38 12-11-2009 10:59 AM
Fun with Voltage Controller Heatsinks Dradus Fossil Fuel Free 14 05-02-2008 03:16 PM
